If I had known then what I know now - I could'a been done 2 hrs ago.
Anyway, I installed the e/c seals today - with your help. Thank You.
Started off bad. Couldn't get the front seal seated in the channel without a lot of ahhh, verbal abuse. I finally used a 'lil vasoline applied to the upper edge of the seal & a BIG flat blade screwdriver to compress the rubber enough to fit it into the channel.
Inch by inch... Rear seal was a piece of cake. Sides, not too bad. But the front was a S.O.B. No $hit.
Here's a couple pics for $hit's & Grins.
BTW - Check my work!!! I don't (really) know what the &^%$ I'm doing so if if doesn't look right, please say so before I stuff the engine back in & go - Doooooh
Thanx, Gary
