I believe this is a column from a 1970. I took pictures from as many angles as possible. If there are higher res pics you would like, I can post them for you. Part number on the column is 914 613 3061.
There are some scratches on the column clamshell but they'll be where you can't see them anyways. Wiring is all good. Looks like the PVC wire loom cracked at some point exposing the wire harness inside. I'll throw in new loom if you would like to change it out.
I also did some further clean-up and lubrication of the bearings and have to say that this is nicer than I thought originally. All 3 keys work very well and the shaft has no play that I can tell.
SOLD PayPal preferred.
Thanks for looking!
