ETMracing
Dec 11 2013, 11:43 AM
Been reading quite a bit of posts from here that date back to 05' and have some great input.
Re-doing my dual carb fuel line routing on my 914/4 2.0. Tank, pre filter, low pressure pump,.....then should it go fpr, gauge, t-fitting, carbs, no return?
Its a 1 in 2 out FPR. And a inline FPG.
Thanks 914World
brant
Dec 11 2013, 11:55 AM
there are benefits of a return line
thats how the factory did it and it does keep the fuel cooler and thus adds power
here is a thread with diagrams
its been discussed so many times that I sound like a broken record:
http://www.914world.com/bbs2/index.php?sho...p;#entry1470608
ETMracing
Dec 11 2013, 12:48 PM
QUOTE(brant @ Dec 11 2013, 09:55 AM)
http://www.914world.com/bbs2/index.php?sho...p;#entry1470608yup been studying that thread, so its okay to run through the first carb and then out to the next?
ETMracing
Dec 11 2013, 12:52 PM
option B it is then, thanks !!
stugray
Dec 11 2013, 04:58 PM
I used:
Fuel cell (tank), filter #1, holley (red) pump, pressure regulator (all in front trunk), fuel pressure gauge (in engine bay) @ splitter, see-thru fuel filter at each carb, feed to each carb,
No return.
Plan on removing the cheap see-thu filters@carbs before racing (but they really help with startup when you leave the car sitting for a few weeks without firing up - you can see when the bowls are full)
r_towle
Dec 11 2013, 06:05 PM
QUOTE(ETMracing @ Dec 11 2013, 01:52 PM)
Fluid dynamics.
Pressure is the same everywhere, no matter how you run it.
