Engine rebuilt by Jimmy Sartwell in Baltimore Md. He builds some of the fastest vw motors on the planet.
Nothing special with this though besides his workmanship. All stock new parts from Porsche besides the crank which was re-ground and balanced. Comes with a new flywheel as well as used good pushrods. The cam has been run in so no break in besides what you feel appropriate for the PC's and heads you choose
If you need this finished I can do final assembly with your additional parts.
Keep in mind though if you need this shipped it will be much less as is and the work to be done is fairly straight forward.
$500
