Hi,
For those of you who have a Tarett hollow sway bar, did you do anything special while mounting the fuel tank after installing the bar?
Once I dropped my tank in with rubber blocks, when I move the sway bar, the tank rocks fore and aft. When I removed the tank, I could clearly see where it was rubbing.
At this point, I'm just thinking about using some rubber sheets as spacers to support the bottom of the tank where it contacts the chassis, but am wondering if anyone else has come up with a more elegant solution.
Thanks,
-bryan
