QUOTE(PotterPorsche @ Dec 18 2013, 01:15 PM)
My brother purchased another 914 project. It currently has a mazda non turbo rotary conversion. It is currently not running, but apparently it ran in SCCA. It also has a radiator kit plumbed to the front. I have been reviewing his options:
Option 1: Spend money on the rotary to determine the health of the engine. Decide the cost to repair the rotary and figure out the wiring.
Option 2 :He still has a type iv 71mmx 101mm long block. Determine cost of repair or rebuild, figure out what's missing, and get it back on the street.
Option 3: convert to 4 cylinder Subaru wrx engine. determine the cost
Option 4: convert to 6 cylinder Subaru ez30d engine. determine the cost.
Looking for input from forum members who have any one of these options 1-4, with pros' and con's.
Also for option 3-4 what real world cost are? what should be considered? Ball park on how many hours these conversions typically take?
I'm chiming in about option #1,, A used Japanese engine can be had for under $1000 for 1988~1992 turbo engine. Everything else should bolt up. Engine rebuilds for rotaries can get expensive (if done correctly) but then you practically have a new engine when you're done. Rotaries die a few ways,, excessive oil consumption, low compression, or someone cooked it by overheating. Check your compression by removing the spark plugs, squirt oil in plug holes,, and crank the engine with the coils disconnected. Then hook up a compression guage with the check valve removed, and install the trailing spark plug, and hook the gauge up to the leading spark plug. Watch the guage needle jump and you should see 3 even compression pulses. Now repeat the process for the other rotor.(rotaries usually only have 2 rotors) If this is confusing,, PM me
Rotary 914s are very unique rides.
Now if you don't want to hassle with learning about rotaries,,,, I'd go Subie
-Robert
