Full Version: Starts out smooth, then what the buck?
Jesco Reient
When I first start the car cold for the day. (2056, D-jet, Raby 9590 cam, timing 27 advance @3500) The car has no cold start valve but has not seemed to care. First start it runs smoothly pulls away from the house shifting @ 3500 it acts nicely. After warming up for awhile as the motor reaches 3200 to 3600 it bucks severely then above 3600 it smooths out a bit. Then as it gets warmer the bucking moves down the RPM range to 2600 to 2800 RPM becoming not very drivable. any ideas out there? confused24.gif
boxsterfan
QUOTE(Jesco Reient @ Dec 18 2013, 04:24 PM) *
Could be TPS worn, trigger points on dizzy or fuel pressure/fuel injector related. You running points or electronic ignition?
Jesco Reient
QUOTE(boxsterfan @ Dec 18 2013, 04:32 PM) *
Running a Pertronix unit in a stock distributor, I'll check the Fuel pressure @ 3500 RPM, The TPS switch looked good, Just had the injectors cleaned and flowed. That's some good things to look at for a start Thank You.
boxsterfan
Also, how about your fuel filter? Clogged?
Or a pinched fuel line up front by the gas tank? Still running original plastic fuel lines in the tunnel or upgraded to SS?
And, as crazy as it may sound, how are all of your electrical grounds? Battery to body and transmission groundstrap are the biggies.
r_towle
What is your valve train setup?
Aluminum or chromoly push rods?
Swivel foot or solid adjusters?
Last time you adjusted the valves?
Rich
rick 918-S
From the sounds of your last post about going through the entire F.I. and refurbishing the vacuum hoses and electrical connections I would start to suspect fuel delivery. I wonder if the fuel pump is weak. Describe the bucking. is it a miss or a stall?
Miss could be from the spark plug wire interfering with the MAPS. Someplace around here there is some info about keeping the plug wire away from the MAPS as it will cause issues.
Stall could be from weak pump.
gothspeed
The above is good advice ..... the only thing I'd add, is maybe the CHT sensor is bad or not getting a good connection.
Mike Bellis
What everyone is eluding to here is you have a lean condition. Lack of enough fuel causes bucking. Other things can too but lack of fuel is the most common cause.
gunny
I had the same type of issue and after about a year of working on it i installed a wideband A/F meter. Found out I was running very lean and it leaned out so much at about 3700 rpms that it would loose power and buck. I had to adjust my MPS to get it running great with no issues now.
Try unplugging the temp sensor #2 on top of the intake plenum. It will richen it up some. If that helps then you may need some MPS tuning.
rmital
QUOTE(gothspeed @ Dec 19 2013, 09:18 PM) *
Ground the connection from the harness to the CHT and see if there's a change
914GT
Maybe try retarding the timing a few degrees and see if it helps. Too much total advance can cause bucking depending on rpms and light engine load.
r_towle
Runs good cold, run worse when hot.
Metal expands when heated.
Check our valves.
rick 918-S
QUOTE(r_towle @ Dec 19 2013, 09:40 PM) *
Check our valves.
I would agree it is always good to check valves I would think it would be less likely that it would cause a specific RPM range miss or bucking. Fuel delivery or.... idea.gif MAPS is starting to crack.
Jesco Reient
QUOTE(boxsterfan @ Dec 19 2013, 08:57 AM) *
Thanks again for the input, Original plastic lines replaced by Stainless Steel lines at the beginning of the build, I have checked all the hoses to make sure that they are smooth with no kinking. Secured the correct groundstrap to the transmission during the engine/transmission installation. I have checked the other grounds back through the harness with a Fluke Multimeter.
r_towle
"What is your valve train setup?
Last time you adjusted the valves?"
The valve train set up is comprised of Raby's spring eliminator spacers, Swivel foot adjusters, Chromoly pushrods, and I just adjusted the valves to zero lash prior to the start up last week. the engine has run well except for the bucking since the valaves were adjusted.
rick 918-S
"From the sounds of your last post about going through the entire F.I. and refurbishing the vacuum hoses and electrical connections I would start to suspect fuel delivery. I wonder if the fuel pump is weak. Describe the bucking. is it a miss or a stall?"
Stall could be from weak pump."
rick, It feels like a plug or plugs laying down, but I'm thinking with my lack of experience with the feel of the D-Jetronic injection an injector laying down could feel similar. I put a fuel pressure gauge on the driver's side fuel rail (a solid 30 PSI @ 3500 RPM) and started the engine and rechecked the timing this afternoon. The timing is now once again verified to be set to 27 degrees @ 3500. I added a new Yellow mark on the fan when the engine is at 0 Degrees TDC, This combined with my computerized timing light with 27 degrees of advance verified the timing was slightly off from yesterday. I am satisfied with the new timing and the car drove a good bit better with a slight stumble at 3400 to 3800 RPM. But still not something I'd hand over to my wife and so go have fun.
gothspeed
"The above is good advice ..... the only thing I'd add, is maybe the CHT sensor is bad or not getting a good connection."
This is next on my check list, in my research today I have found that if I have the 1974 sensor in my 1973 set up it may not act correctly, I have also found out today that there is supposed to be a resistor inline on the 1973 2.0 litre D-Jet cars that I don't have inline. Brad Mayeur has told me it needs to be a 270 Ohm resistor. That and I may attempt to swap in a different distributor and see if the problem stays the same or goes away.
The advice regarding the wideband A/F meter is interesting which one did you use? I can also check the resistance of the different sensors again and make sure they are still in specifications.
The end result is the car was barely drivable today, so I took it for a short test drive, better than yesterday but tomorrow will be a day of rest for the little car.
Thank you all for your input I'll keep you apprised of where it is at.
rick 918-S
You may want to re-run a test on your MAPS too just incase it is starting to crack.
gunny
http://www.aemelectronics.com/wideband-air...-fuel-gauge-25/
AEM digital Wideband air fuel gage. I also added a vacuum gage so I could monitor the vacuum and A/F mixture while driving under diffrent conditions. took about a week of test drives now car has a lot of power throughout the RPM range.
I also have a LCR meter so I can keep track of the adjustments to the MPS. Small adjustments to the MPS make signifcant changes to the A/F mixture
Jesco Reient
QUOTE(rick 918-S @ Dec 19 2013, 08:28 PM) *
Check our valves.
I'm in denial on checking that also but might as well, otherwise I'm just lying to myself. The somewhat progressive nature of this has had me thinking about that diaphragm in the back of my head.
boxsterfan
http://members.rennlist.com/pbanders/DJetP...tm#troubleshoot
I assume you have been going through the info in this website. It was very helpful me to me when I started out (and still learning D-Jet).
One thing listed here that is relevant to you is:
What:
Engine "bucks" or jerks at steady part-load throttle settings
Check these:
Throttle switch contacts worn
Dirty, worn, or misaligned trigger contacts
Fix with:
Replace throttle switch. See throttle switch section above for more detail. If condition
persists after testing the throttle switch, it may be due to defective or misaligned trigger contact points.
Maybe you could borrow a known good TPS from someone?
r_towle
QUOTE(Jesco Reient @ Dec 20 2013, 12:46 AM) *
r_towle
The valve train set up is comprised of Raby's spring eliminator spacers, Swivel foot adjusters, Chromoly pushrods, and I just adjusted the valves to zero lash prior to the start up last week. the engine has run well except for the bucking since the valves were adjusted.
So, there may be a clue here...
just saying.
My 911 did this.
I fixed everything and replace alot of the vacuum, ignition etc.
I adjusted the valves, problem solved.
Loosen them up.
They will just be louder.
They will then close all the way when hot.
This may fix the issue.
You may need to adjust the valves more than a few times to determine the exact setup your specific motor will run correctly at.
Metal is different from your motor to mine.
There is no one answer that works for each motor.
Search google on Chromoly push rods and valve lash adjustments.
Lots of opinions, lots of research.
Summary, at least my summary, is your motor is not the same as any other motor on earth.
Your cylinders, heads, springs, valves, camshaft, and lifters would all produce different expansion results than any of mine.
So your valve adjustment would end up being different than mine.
Loosen them up, let it be loud to see if the bucking problem goes away.
Then walk them back towards a zero lash slowly until you find the sweet spot for your motor.
rich
rhodyguy
have you calibrated the tps using a proper plug, jumper wires, and your multlmeter?
gunny
If the issue is RPM sensitive and not throttle position sensitive (like mine was) then it's not the TPS, my experance.
When you have the bogging/bucking at an RPM can you pump the throttle to get thru that RPM range? When you get above the RPM range does the car run fine? if so it's because you are very lean at that RPM.
What year is your car ECU and MPS from?
Jesco Reient
Today has been a research and reading day, letting the car sit for today and maybe Saturday, I also have a small block Ford to tear down this week that is getting ignored as the little German car has yelled at me to work on it. LOL
Thanks everybody for the continued input.
Jesco Reient
QUOTE(gunny @ Dec 20 2013, 09:40 AM) *
1973 2.0 D-Jet parts
Jesco Reient
QUOTE(rhodyguy @ Dec 20 2013, 09:22 AM) *
Hey I'm back,
So The Ford motor is disassembled and I'm back in the shop with the 914,
As suggested I tried running the head temp sensor to ground to see if that changed anything, not really So it's hooked back up now.
Next I'm adjusting the TPS again with the multi-meter.
Next after that I'm checking the Manifold Pressure Sensor Diaphragm.
It feels like it's closer to carburetors everyday.
Argghhh
Java2570
I've seen a lot of other threads with folks using either Raby's 9550 or the Web 73 cams
needing to spend time tuning to get their AF mix correct. If you are running 1973 D Jet
parts, you will likely at least need that 270 ohm resistor pack but I'm thinking an
AF gauge would be the best bet. Even on my completely stock 2.0L with working MPS the engine tends toward the lean side. Don't give up on D Jet please! Jon
I had bucking sometimes and a perfect running engine other times. I changed the coil on mine and the bucking went away. I had tried all the other suggestions. Just a thought.
Once you get it fixed you will be glad you did not switch to carbs.
Jesco Reient
QUOTE(mepstein @ Jan 23 2014, 07:09 AM) *
The coil has been nagging at my mind since that is the only part NOT replaced during the rebuild, I just have not gone there yet.
The TPS is set again by the ohm-meter method, and the resistance readings on the MPS were right on the numbers.
rmital
QUOTE(Jesco Reient @ Jan 22 2014, 07:59 PM) *
............As suggested I tried running the head temp sensor to ground to see if that changed anything, not really So it's hooked back up now.
just to be perfectly clear....you are NOT running the head temp sensor to ground.
you would run a wire from the pigtail connection from the harness that connects to the head sensor to ground (negative on the battery)
your taking the CHT out of the equation.
r_towle
QUOTE(Jesco Reient @ Jan 23 2014, 10:37 AM) *
Have you removed and cleaned the advance plates inside the distributor?
Jesco Reient
QUOTE(rmital @ Jan 23 2014, 09:28 AM) *
Yes, I was unclear, I ran the head temp sensor pigtail of the injection harness to the negative terminal of the battery.
Jesco Reient
OK, todays test drive revealed a nice smooth pull with no bucking up to 5500 RPM, then I shifted and feeling good about everything started to head out for a drive. not long after it sounded starved for fuel and shut down. So I headed back to the shop, and as I got close to the shop same thing. Back at the shop I held the RPM at aout 2500 RPM and within about three minutes same thing just sitting still.
So I'm replacing the fuel filter first thing tomorrow, then I'll hook up the pressure gauge with a long hose and see what happens when I go for a drive. But for now the bucking has left the building.
Looks like the TPS was the major culprit.
Thank You to all that helped.
