skline
Dec 30 2004, 10:43 PM
I look at my car from the back and the drivers side wheel is straight up and down, the passenger side is tilted in at the top. Do I add or remove shims to bring it upright?
Aaron Cox
Dec 30 2004, 10:44 PM
add shims for positive camber IIRC
my car has no shims and -2 deg camber
skline
Dec 30 2004, 10:51 PM
Well, mine has 3 in there and it is visibly tilted inward at the top. I am not liking it either. I dont recall it being like that before moving the car around.
Aaron Cox
Dec 30 2004, 10:56 PM
QUOTE (skline @ Dec 30 2004, 09:51 PM) |
Well, mine has 3 in there and it is visibly tilted inward at the top. I am not liking it either. I dont recall it being like that before moving the car around. |
bent? i could be wrong....IIRC shims = + camber
Duffster
Dec 30 2004, 11:01 PM
I'm not sure that this much application, as that Shalom has pretty good wheel well cut outs, but FWIW I'm running about 4 degrees negative to clear the fatties on the rear of mine. If you wind up with those red thangs on it, you'll want some negative camber... limited of course by how much you feel like grinding off the inner fender wells
Dec 30 2004, 11:33 PM
QUOTE (skline @ Dec 30 2004, 08:51 PM) |
that's not gud!
add shims for +, remove for - ...
usually, if you have a lot of shims and still - camber, your trailing arms are bend !!!
ask me how i know ...
Andy
skline
Dec 31 2004, 12:02 AM
Can they be bending right now? I have the boxed trailing arm stiffeners welded on but I would swear it is getting worse.
Aaron Cox
Dec 31 2004, 12:05 AM
QUOTE (skline @ Dec 30 2004, 11:02 PM) |
Can they be bending right now? I have the boxed trailing arm stiffeners welded on but I would swear it is getting worse. |
did they warp when you welded on the kit?
how could it be getting worse? check your bushings for wear, check the suspension ear for ovaling
skline
Dec 31 2004, 12:10 AM
My other concern is my front spoiler, I cant even get my shoe under the front lip of the spoiler. The toes go under but it hits on the instep of my foot. It couldnt be more than 3 inches from the ground to the spoiler. That seems a bit low to me. It looks pretty cool but being fiberglass, it wont last long going in driveways. I need to bring it up to at least 4 or 5 inches. Anybody want to come help me set it up so I can get clearance?
jim912928
Dec 31 2004, 11:38 AM
If you think your camber is changing noticeably...I'd check your bushings. If they are the original they might be disintrating in chunks as we speak since they are now being stressed. Maybe they also got too hot/hard/brittle after the welding and they are breaking away?
Mueller
Dec 31 2004, 11:43 AM
make sure your rear springs are seated correctly, one side might not be in position after raising and lowering the car????
Joe Bob
Dec 31 2004, 12:03 PM
I have extra shims if you need them....the boxed arms are REAL easy to warp unless they were in a jig when welding. I fuched them up on the Rocket....had to do it twice.
As to the front spoiler....."I" used a stiff rubber lip and cut the fiberglass up a bit.....I am always doing a kamikaze on speed bumps, steep driveways and curbs......
BTW...you can get the shims when ya come up for the trailer.....
Dec 31 2004, 01:44 PM
QUOTE (skline @ Dec 30 2004, 10:02 PM) |
double check your suspension console and make sure it's not cracked ...
they start sagging when they crack.
Andy
Jeffs9146
Dec 31 2004, 01:57 PM
QUOTE |
QUOTE (skline @ Dec 30 2004, 10:02 PM) I would swear it is getting worse.
double check your suspension console and make sure it's not cracked ... they start sagging when they crack.
Andy
Check your suspension ear! It could be ovaled out!
Jeff
Jeffs9146
Dec 31 2004, 02:00 PM
Chris Julian
Dec 31 2004, 02:04 PM
Scott, double check the large castle nuts. If you recall I had this issue (loose nuts- he he) a while back and it kicked the tire out (or in @ the top) by close to 1/2".
Chris
