opera guy
Dec 31 2004, 02:53 PM
just reinstalled my S-shaped ducts for some heat for these winter months. i noticed im loosing torque. before.. i can go from 65mph to 90mph in a jiffy, now it takes a lot longer even with WOT grrrr
i do need a valve job, but is this normal when you put your heat stuff back on?
Dec 31 2004, 03:04 PM
QUOTE (opera guy @ Dec 31 2004, 12:53 PM) |
is this normal when you put your heat stuff back on? |
nope. the two have nothing to do with each other.
but, exactly what part are you refering to when you say "S-Shaped duct" ???
maybe the heater blower sucks too much fresh air away from your engine? do you still have the rain-tray on your car?
Andy
McMark
Dec 31 2004, 03:16 PM
The heat exchanger to body ducting pieces.
Dec 31 2004, 03:21 PM
QUOTE (McMark @ Dec 31 2004, 01:16 PM) |
The heat exchanger to body ducting pieces. |
mine are straight, not s-shaped ...
Andy
rhodyguy
Dec 31 2004, 03:50 PM
they direct the air that is pouring out the open end of the h.e.. should have no effect on your power loss.
rhodyguy
Dec 31 2004, 03:54 PM
oops, senior moment. they direct the air coming form the cooling fan to the h/e.
kevin
Dec 31 2004, 04:08 PM
oh, those!
i tought he was talking about the flex rubber part that goes from the flapper to the body ...
sorry, my bad ...
Andy
Joe Ricard
Dec 31 2004, 05:32 PM
Unless you have the complete set up you can loose lots of air through the up right pipes. These are supposed to lead to the fan which has a flapper valve to prevent ait from going out of the blower defrost fan
opera guy
Dec 31 2004, 05:34 PM
ah, the driver side j-pipe is open. i'll look into capping that. thanks guys
rhodyguy
Dec 31 2004, 05:37 PM
if you don't have fan tubing on the j-tubes, 2" rubber pipe caps in the plumbing section of your local hardware store work great. they usually come with clamps too.
kevin
Mueller
Dec 31 2004, 05:47 PM
just bad luck, those parts have no bearing on how well your motor runs.....look for loose wires or something else you might have bumped....
