QUOTE(gcrotvik @ Dec 31 2013, 11:04 AM)
QUOTE(Tom_T @ Dec 31 2013, 09:34 AM)
Greg,
Maybe some of the local PNW-teeners will have a car with their color sticker still intact close enough to you for reference?
Tod914 may be another reference for the size & material, as he's restored several 73-74 preservation class 914s over recent years, although I think all are sold now, but he may have good pix & idea of size. PM & email him off the search members, cuz I've not seen him on here for awhile & I think he was moving from NJ to TX too.
I'm restoring my 73 2L L80E as well, so would be willing to share repro costs with you if not too much, to make one for my resto. Just send me an email/PM when you have costs & more info.
If you can repro with the ability to drop in any color code & name, then you'd get a better audience/customer base, and 911/912 guys would also be possibles too, as I think the stickers were the same (you'd need to research that).
Cheers!
Tom
Hi Tom,
Thanks for the help. I will PM Tod. I found a label company that will print just about anything. They have the foil labels and, if needed, will cut custom sizes. I have ordered just about ever stock size label that would be close but I cannot get a tight bead on the size.
See the pictures below. I didn't stick the label down fully on my car but I wanted to see how close I was getting. At this time, too narrow of a label and the corners are too rounded.
I'm working on the font also. The one I used is close. Let me know what you think.
Greg
Greg,
Their font was a condensed font - Helvetica or similar I think, and maybe the semi-bold vs. your bold font standard width.
Corners are indeed more rounded than original, but you could use square & cut round corners with an exacto knife & circle template for closre radius.
I think you can measure the nuts & door hinge base on your car, then use that to compare to Jeff's pic to measure size of label proportionally, using the known bolt head &/or hinge measurement.
Also, SocalAndy on here has the thread to make repro VIN door stickers, if you'll need one of those as well, so PM/email him if necessary.
I still need to get one from him too, but I'm still at your early 2012 stage, although I've owned my 914 since 12/75 (2nd owner also).
Hope this helps!
Tom
