rhodyguy
Dec 31 2013, 08:49 AM
haynes, i get #11 in the procedure but how much "lightly tighten" is "lightly"? to the point of inducing a little drag? then back off on the clamping nut so the nose washer can just be moved. as in barely using any pressure to move the washer with a screwdriver? and to confirm, 11lbs of torque on the clamping nut screw? tia. happy new year!!! don't drink and drive!!!, and look out for those who do.
pcar916
Dec 31 2013, 09:12 AM
It's a "feel" thing. I tighten mine until the washer is slightly moveable (with a little screwdriver effort) and drive the car. If needed I keep tightening it, a tiny bit at a time, until the vibration at highway speeds (60-70) goes away.
Mine has to be slightly tighter than a stock wheel because I'm running 225/50-16 wheels and spacers on the front. They're tighter... but not much. I used to inspect them every six months or so to make sure they weren't burning.
But since they never were I inspect/repack/replace once a year. On a strictly street car I wouldn't replace until I saw pitting or heat discoloration.
The thought of spinning a bearing on the spindle scares the crap out of me. I use only synthetic grease on bearings.
Good luck
