QUOTE(Marv's3.6six @ Jan 1 2014, 12:39 PM)
QUOTE(904svo @ Jan 1 2014, 11:41 AM)
Try using a pair of pliers to squeeze them.
Thanks. But is there anything better or more precise than simple pliers. Just askin ?
If you're just trying to get the push-fit connectors to bite harder, then no - use some flat-nosed pliers and just squeeze *gently* to tighten them up a bit. It takes a bit of practice to judge how much - too much and you won't be able to get them back together.
As you push them back on, they will cut a fresh groove into the spade, and usually that will greatly improve the connection.
