QUOTE(McMark @ Jan 2 2014, 07:52 PM)
If any are available, they're in Brad's hands. The rotor is a stock 911 piece and bolts on from the back with five M8 bolts. The real intent of the pieces was to install larger calipers and vented rotors on a four lug setup.
Right, probably the best way is to drill the fronts and sides of the hats to reduce weight. Or maybe someone has a CNC to machine them in aluminum, with bolt on rotors, or titanium?
Titanium would be super light, but probably big $$ I'm guessing.
I just wonder what a Titanium hub, with a titanium rotor would weigh?
A Ti hub would be heavier than it's aluminum counterpart. If I were making hubs I would probably use something like 2024 Al because of it's combination of elevated temperature strength and specific stiffness. You could then get an Al-SiC MMC (metal matrix composite) rotor.
