The master cylinder was shot on my '70 914, so i ordered a new 19mm replacement. While removing the old one a couple of the hard lines broke, so i went ahead and ordered new hard-lines for the front of the car. Once getting everything back together i went to bleed the brakes and nothing happened, I eventually pressurized the reservoir to 15psi and used a bleeder pump in the back also set to 15psi, and eventually got a little fluid and a lot of bubbles. I then moved on to the front and I am getting nothing up there, the reservoir itself has most of the fluid still in there. With the brake down I get no resistance in the back or the front.
My assumption is that this is an issue with the initial feed of fluid from the cylinder itself, probably on that tricky spot where the hose attaches to the master cylinder, but figured I would see if anyone on here has any insight on what else might be wrong.
There is no fluid leaking from anywhere, even when pressurized. The BMS was installed dry. Once again, and guidance would be greatly appreciated.
Thanks.
