QUOTE(boxsterfan @ Jan 3 2014, 03:30 PM)
One of my other projects this winter is to get an oil pressure gauge installed. I want to use the dual-sender unit (can purchase from PP or wherever).
I have read before that some people take out the original sender and install a hose and then attach the dual-sender to that hose. Of course, wiring from there to your gauge and idiot light. For those that have done this:
1. What kind of hose? And size of hose ends?
2. Where did you mount the sender and how? Pic helpful....
TIA...
Stand back, a shitstorm is likely about to happen. Personally, I use a readily available grease gun hose with a 1/8"NPT male fitting on at least one end. Some say a paintball hose works. You have to wire a ground for the sending unit housing. I mount them on the fan shroud, using a plastic covered ring clamp, like the ones used to route hoses and wires in a hot rod. I've done this on a lot of cars over the years and it works well. Be sure the sender you use matches the characteristics of the gauge, and the cutoff pressure for the lamp.
The Cap'n
