The crux of the failures is rust/corrosion in the main bore of the cylinder.
Once the bore becomes pitted the, wiping of the bore wall by the seal is compromised.
IIRC this is compounded by the two different metals used: the Plunger=Alum & the Cylinder itself=steel.
Its pretty easy to determine if this is a problem as a simple large snaplock/circlip holds the plunger in the bore once removed you can usually see if you have damage.
