Mikey914
Jan 7 2014, 10:53 AM
A few of you were looikg for these and I made some up. Polycarb rear back glass. The polycard is lighter than glass and will not scratch as easily as acrylic.
I have them up them on the website
http://www.shop.914rubber.com/914-rear-bac...te-914PCRBG.htmI have a piece of rear glass on the bottom one in the picture of 3 so you can ssee the fit.
I do have a second that was a mistake we scratched it with the cutting blade when we removed it. I'm posing it in the classifieds for $50+ shipping
Thanks all
palmer_md
Jan 7 2014, 11:49 AM
QUOTE(Mikey914 @ Jan 7 2014, 08:53 AM)
Thanks all
Just curious. How much weight savings is there in this small window? I would think the bigger savings is in the sides and windshield. Do you offer those as well?
Woody
Jan 7 2014, 12:52 PM
Can you also do side windows?
CptTripps
Jan 7 2014, 02:43 PM
QUOTE(palmer_md @ Jan 7 2014, 12:49 PM)
I was going to ask the same thing. Well, I guess I could weigh one of mine when I get home and we can guess from there. I can't imagine the Polycarb one is more than 2-3lbs.
FlatIV
Jan 7 2014, 05:22 PM
Any idea on how this will effect noise levels?
Mikey914
Jan 8 2014, 02:31 AM
I will be able to to do the sides and front in acrylic as they have to be formed. I would possibly offer a flat version of polycarb for the front.
Weight savings is about 2-3 lbs, not a ton, but it adds up.
Mikey914
Jan 8 2014, 02:32 AM
QUOTE(FlatIV @ Jan 7 2014, 03:22 PM)
Should be simular as the thickness is about the same.
Maltese Falcon
Jan 8 2014, 10:51 AM
Mikey, just curious on the material thickness ?
Put one aside for us , I'll pm you later today.
Marty
Maltese Falcon
Jan 8 2014, 11:01 AM
Did you ever plan on making a short run of this type of window;
as seen on member JM993RS car?
Click to view attachment Marty
Woody
Jan 8 2014, 12:19 PM
I'd be down for a full set if you think you can do it.
Mikey914
Jan 8 2014, 07:48 PM
They are 1/4".
I had not see the side window slider like that before, doable, but I need to walk before I run on these. The front windshield is next. I know most guys use a flat piece and screw it down. Would be cheap and "easy" I can cut those in Poly.
To form it I do need to use acrylic. I do need to make one before the other, so both could be cut at the same time.
How many would be up from fronts? I need to figure out the yields which means diggin into this a bit more. I have a fe wother projects that I need to warp up before I can give this attention, but if there is a demand I'll add this to the list.
-Mark
76-914
Jan 9 2014, 09:46 AM
Huh? I always thought polycarbonate was softer and does scratch easier than plexiglass. Are the edges radiused or relieved to prevent cracking?
palmer_md
Jan 10 2014, 02:53 PM
QUOTE(Mikey914 @ Jan 8 2014, 05:48 PM)
They are 1/4".
-Mark
Acrylic is good for the rear window and even the sides and the top you offer, but I would not like to have an acrylic windshield. I would rather have Lexan/polycarbonate for the windshield for safety. Even if it scratches, its better than shattering and letting the object come into the cabin.
Mikey914
Jan 12 2014, 03:25 PM
Plexiglass is a trade name for poly carb. They are basically the same. Acrylic can scratch easier, and can crack and break. It is used in aircraft windshields so I'm sure the automotive application is fine, other that scratching. It can be polished. Poly carb is ideal for a windshield, but it requires special treatment to thermally form it making the cost at least double.
ConeDodger
Jan 13 2014, 01:06 PM
Mark,
McMark and I will be looking for at least the back and two sides for an upcoming race car project.
effutuo101
Jan 13 2014, 06:21 PM
Low on my list, but, back and both door "glass" are on my list for late this year.
