QUOTE(mikesmith @ Jan 9 2014, 02:12 AM)
One of the VDO cockpit gauges claims to work with the VW classic beetle sender, which is the same calibration as ours. You cannot connect more than one gauge to the sender, however.
ah so I can't really splice into the wire. I have to disconnect the stock on and connect to the add on.
With the gauge powered but but no sender wire (say the wire broke); will it read at zero or all the way up?
Does the ground from the sender make the needle go higher or lower? trying to see if the gauge even works...
