QUOTE(PanelBilly @ Jan 8 2014, 11:51 PM)
I did get the 6AL 6420. Where on the firewall should it be mounted?
Almost anywhere, even in the trunk, the stock six the CDI hung from the front of the battery tray. If you are using FI keep it far away from the FI ECU
Also keep in mind the MSD can be splashed with water but shouldn't get soaked. Don't mount the box on the engine and only the MSD high vibration (epoxy filled) coil can be mounted on the engine. The other MSD coils (oil filled) should be mounted standing upright on something like the firewall etc.
