Eric_Shea
Jan 8 2014, 05:17 PM
After digging around for a while we finally found a vendor for the M6 handbrake arm pin and safety clip.
Sign in, these are in stock and shipping now. You can remove your bolts and nuts and do it right! (I know... that's no fun.)
$4.48 per pair "with" the clip.
In the "Member Vendor" section now.
http://www.914world.com/bbs2/index.php?showtopic=228333
porbmw
Jan 8 2014, 05:30 PM
Hey Eric
Sign me up!...
But I'll have to get back to you as to number needed...have lost track of number needed....
Just so world members know....these are elusive to find!
Good job on getting a supply!
Paul
Mblizzard
Jan 8 2014, 05:51 PM
Already ordered mine! Actually ordered them twice but that is a whole different story. These will be the finishing touch to my rear calipers! Thanks Eric.
914werke
Jan 8 2014, 07:43 PM
There are actually 2 lengths necessary. The shorter length pin is used for the E-Brake cable ends at the brakes.
The longer one is also used for the E-brake mechanism but secures the balance pivot to the end of short cable in the cabin.
Chris Pincetich
Jan 8 2014, 07:51 PM
I need the one that works on the balance pivot inside the cabin.
Is this the correct part?
Looks purdy, I should just order it and add it to the pile
02loftsmoor
Jan 8 2014, 08:48 PM
please pt me down for one Wes
Mike Bellis
Jan 8 2014, 08:53 PM
I want 2 set 'cause their cool!
Socalandy
Jan 8 2014, 08:59 PM
2 sets please
McMark
Jan 8 2014, 10:01 PM
10 sets for me. Seems like every car is missing these, often replaced by bolts which is not a good idea.
r_towle
Jan 8 2014, 10:25 PM
M6 handbrake
CptTripps
Jan 9 2014, 08:05 AM
What's the total number needed to do the entire car?
I want to make sure I'm doing this right.
Eric_Shea
Jan 9 2014, 01:06 PM
You'll need a pair.
These are for the ends of the handbrake cables at the caliper, "not" the pivot yoke inside the cabin.
rjames
Jan 9 2014, 01:44 PM
Thanks for getting these done. I just placed my order for two of them and it took me less than a minute to complete the transaction!
lonewolfe
Jan 9 2014, 02:44 PM
QUOTE(Eric_Shea @ Jan 8 2014, 03:17 PM)
http://www.914world.com/bbs2/index.php?showtopic=228333Hey Eric!
I'd like to buy 3 of these from you!
Thanks,
Mark
bdstone914
Jan 9 2014, 03:25 PM
Eric,
Any chance your source has the 6 x 18mm pins for the E brake handle to cable and equalizer?
The handle pins are almost always rusted beyond use.
Bruce
DRPHIL914
Jan 9 2014, 11:25 PM
Eric,
I just wanted to say thanks . When I called about theses last week I had no idea you would get some so fast! Don't know if you had already been looking but that was great timing.
I must be one of the first ones to get them. After I pulled my calipers a couple weeks ago and I found these on my car rusted into one solid mass! must have been the originals. Already began I stalling my cables.
They will really look nice on my newly zinc plated calipers!!
euro911
Jan 9 2014, 11:42 PM
Are these compatible with any other P-car E-brakes? (911/912)
