QUOTE(Kansas 914 @ Jan 10 2014, 05:51 PM)
Mark,
Do you remember the finished diameter after the process?
Just a couple mm inside the mounting hole pattern.
The issue I ran into was that a PO riveted in an early shift pivot assembly from an early car (and installed a tail shift trans) into a '75
If that weren't bad enough, it was crooked and placed a lot of tension on the shift rod going through the plastic bushing
When I removed the assembly, I found that the original hole had been enlarged and there was nothing to mount the bearing to
The quick fix: fabricated an aluminum plate to fit the recess
However, the plate took took up more than 1/8" of free space, causing the shift knuckle to hit the bearing on forward movement, not allowing full engagement into 1st, 3rd or 5th. Machining the bearing housing and boring a hole in the plate to match that smaller diameter allowed me to recess the bearing to gain back the required head room
As you can see, I am not a CW
Thanks for the details. Well written and documented.
