Ok. I'm learning English I read a lot here in this forum and it will always better.
"Hallo Gustl,Wolfgang "
You are Right, Yes, it is the vertical fan
Ok topic Oil cooler
Click to view attachmentClick to view attachmentClick to view attachmentFirst I had an oil cooler, rear right next to the Gearbox. Was not bad, but the hot air from the heat exchangers is not really top.
Now I have installed the oil cooler in front and is all good.The oil Temperature never goes above 110 ° C degree
No the Fan shroud is from a Germany Faktory . His Name ist "Orratech" He has a Horizontal Fan for a T4 Engine. This Factory is work for my Engine
Click to view attachment"For a 2.7 T4, it will be way lighter than the 2.7 6 cyl.
Just like free horsepower smile."
Ok the 6 engine is a fine thing but very very expensive here.
Another problem we have here in Germany.
I've written that we have in Germany the TÜV. (Technical Inspection Association) The problem is when rebuilding the engine on 6 Zylinden one must also convert the whole suspension ... otherwise you do not get approval. When tuning with the T4 engine which is much easier.
Performance with T 4 engine is not a problem.
Last year i have a 2.4 T4 engine installed wis ca 160PS Horsepower.
Was already looks good to drive here ...
http://www.youtube.com/watch?feature=playe...p;v=XjBzUBRjhsg
