QUOTE(worn @ Jan 12 2014, 01:00 PM)
I am dong the 911 rear brake conversion using m calipers. Maybe i will get aluminum some day Eric. So i have the 911 brake backng plate. It fits. But what about the original bearing retainer? Do i cut that down so it fits?
The 911 PET shows a retainer inside the brake backing plate. They are available new, although that would probably be pretty much the same as the 914 plate without the strenghening flanges.
I am guessing that the brake backing plateis now meant to be the bearing retainer, and also adding more would offset the rotor in a bad way. Help?
Second question is about stiffening tubes in the trailing arm. When i see a torsion box, i automatically think about diagonals. Yet, in Erics version, which is all i have seen, the tubes go straight through. Easier and strong enough?
As always, thank you for your time and effort. My 3.2 came from Pennsylvania. Rusty guide plates between the cylinders, and Lots of gunk! Getting cleaner though, so thinkng suspension soon.
I added the 911 e-brake backing plates/boxster calipers to my 914 rear control arms and this is what I came across while doing this.
The bearing mounting holes on the control arm need to be ground down a little for the 911 backing plate to fit flush.
There is two pieces to the 911 e-brake backing plate that you need. I'm not sure if the later version is different but I used a set off a 70 911 which came with a backing plate(holds the e -brake pads) & a bearing support plate(kinda like the 914 piece but all flat). If you use the 69-73 911 5 lug hubs they fit the 911 bearing w/o any problems. If you use the 74-89 hubs you will need a spacer between the hub and bearing surfaces.
You will need to weld a 30 mm bracket to the control arm to support the e-brake pads when they are at rest. You will also need to weld in a pivot mounting block for the bellcrank(if you go this route).
Then you need to figure out how the e-brake cable is going to actuate the e-brake pads. I used a small cable along with the factory cable to pull on a bellcrank.
You could just buy the Tangerine cable kit and call it a day or make something up like I did.
Here's a few links to check out.
http://www.914world.com/bbs2/index.php?showtopic=88772http://www.914world.com/bbs2/index.php?sho...=106793&hl=http://www.914world.com/bbs2/index.php?sho...c=54987&hl=http://www.914world.com/bbs2/index.php?showtopic=95956http://tangerineracing.com/brakes.htm
