Kaduku
Jan 14 2014, 09:29 AM
I pulled out my OEM shift knob to see if my new shift would fit. Yanked on it and after some effort it came out. I then found out the new knob don't fit, so when I tried putting back the old knob, it goes in super loose.
Did something else come off? I checked everywhere in the cabin and can't find anything.
ClayPerrine
Jan 14 2014, 09:32 AM
Sounds like the crush sleeve is missing.
chads74
Jan 14 2014, 09:35 AM
Forgot to mention...With the new knob I had to cut a little piece off a coke can and use as shim.
Kaduku
Jan 14 2014, 09:37 AM
QUOTE(ClayPerrine @ Jan 14 2014, 07:32 AM)
I looked it up and saw how this thing looks like. Expensive for a little thing.
Will get a bigger flashlight and will search for it again. Thanks"
Kaduku
Jan 14 2014, 09:39 AM
QUOTE(chads74 @ Jan 14 2014, 07:35 AM)
Unfortunately the new one I bought requires a smaller diameter shaft. Too bad I really like the way it looks.
chads74
Jan 14 2014, 09:54 AM
Oh that sucks. Sorry!
JawjaPorsche
Jan 14 2014, 10:21 AM
TheCabinetmaker
Jan 14 2014, 10:37 AM
The crush sleeve is probably stuck inside the oem knob that you took off. When installing the sleeve and knob; put the sleeve on the very end of the shaft, gently slip the knob on till it stops, then smack it with the heel of your hand.
porbmw
Jan 14 2014, 01:43 PM
QUOTE(Kaduku @ Jan 14 2014, 07:37 AM)
I think Mark/914rubber may sell the crush rings
VaccaRabite
Jan 14 2014, 07:00 PM
You can also use paper or felt as the "crush ring."
Cut 2 two inch x 1/2 inch strips of felt.
Put them over the top of the lever like an "X"
Press the knob over top. Works like a charm. I've got knobs on all sorts of tools with this type of fitting. A ton cheaper then the actual rings too.
Zach
Kaduku
Jan 15 2014, 01:25 PM
QUOTE(chads74 @ Jan 14 2014, 07:54 AM)
Chad,
The one I got from you fits. It was the one I bought before getting yours. Your knob is on my car now.
