Mikey914
Jan 16 2014, 01:57 AM
After looking around and only finding a Volvo guy that had these, And looking at what it takes to make these I decided that these needed to be addressed.
You pay more for just one, but now you can get all 4 for less!
These are in production and will be ready in about 14 days. So if you want these just post here, and ill let you know when they are ready.
-Mark
Mikey914
Jan 16 2014, 01:58 AM
More
Mikey914
One more
914werke
Jan 16 2014, 07:44 AM
I need a gross of these.
JawjaPorsche
Jan 16 2014, 07:58 AM
Looked but could not find a tutorial on how to replace the boots. Is there one on how to remove the connectors to slide the new boot on? Any help would be appreciated.
Niklas
Jan 16 2014, 08:27 AM
What is the price ?
rmital
Jan 16 2014, 08:34 AM
QUOTE(JawjaPorsche @ Jan 16 2014, 08:58 AM)
curious too on how easy to replace...and then would like 2 sets; (8) boots
914werke
Jan 16 2014, 08:55 AM
Requires a very small, slight flat blade tool like a jewelers screwdriver to depress the locking tab on the female blade connector.
You can then remove the plastic plug end, install the boot, re-bend the locking tabs, insert the blade connectors back into the plug & Viola!
no1uno
Jan 16 2014, 09:07 AM
I'll take a set
Niklas
Jan 16 2014, 09:51 AM
I take 3 set.
Niklas
David_S
Jan 16 2014, 11:12 AM
Just in time because I need a set !!! Put my name on the list please !!!!
watsonrx13
Jan 16 2014, 03:51 PM
I'll take a set.
--- Rob
luskesq
Jan 16 2014, 04:05 PM
I'll take two (2) sets Mark. Thank you.
Keith
McMark
The two pole connectors that go with these would be handy. AFAIK, they are not available.
Mark Henry
Jan 16 2014, 04:14 PM
This is just for the small early connectors right?
The later L-jet style conector didn't have these...or did they?
walterolin
Jan 16 2014, 05:00 PM
Two sets.
Thanks for doing this stuff.
Mike D.
Jan 16 2014, 06:49 PM
I'd take 4 sets
thanks!
McMark
Jan 16 2014, 07:21 PM
Yeah, Mark. Early only. If your fuel injection harness has small white plastic connectors at the injectors, these are for you.
Mikey914
Jan 17 2014, 02:45 AM
I did make these a little softer (more stretchy), so they may work for both.
Montreal914
Jan 17 2014, 10:22 PM
I am in for a set.
Thanks
OU8AVW
Jan 18 2014, 11:49 AM
I'll have a set, thank you.
