cpfoster
Jan 18 2014, 10:09 AM
Need the rear trunk floor pan for restoration of '74 Zambezi green 2.0L that is finally ready to go to the shop for light body work and paint.
Need especially the area most prone to rust, where the trunk pan seam is under rear tail lights.
Will pay cash or have a lot of parts if want to trade.
Can pick-up / cut out myself if an hour or so drive from Washington DC or Baltimore area.
Thanks,
Chris
bdstone914
Jan 18 2014, 11:55 AM
Probably best to buy it new. I have not seen many parted out cars with a good trunk floor.
Restoration Designs has them.
http://www.restoration-design.com/mm5/merc...oduct_Code=P335
cpfoster
Jan 18 2014, 12:39 PM
QUOTE(bdstone914 @ Jan 18 2014, 12:55 PM)
http://www.restoration-design.com/mm5/merc...oduct_Code=P335Thanks, I was thinking the same thing, but figured I'd throw the "Hail Mary" out there
Jan 18 2014, 03:10 PM
http://www.restoration-design.com/mm5/merc...oduct_Code=P335 the back of the trunk is usually rusty under the seam sealer.
cpfoster
Jan 18 2014, 07:36 PM
I'll take the advice and just get the repro panel - thanks guys !
barefoot
Jan 19 2014, 05:19 PM
Got mine from AA slightly lower price than rest.
here's what was left, used some small panels for hell hole area.
cpfoster
Jan 19 2014, 07:30 PM
Barefoot - Thanks for the pic, I need the piece of the the metal on the right edge of the pic you posted. I'm working on a trade with Vysoc now for the repro panel. Will let you know if something falls thru.
Thanks,
Chris
