QUOTE(stugray @ Jan 21 2014, 12:40 PM)
You have a vacuum leak ..........
I thought that a vacuum leak would make it run lean because there is more air entering the system than is being measured so too little fuel is being added.
Just curious.
porschefile2010 - Do you have any friends with an Air Fuel Ratio meter?
You can get the kind that you just stick up the tailpipe.
That would tell you right away if you are running rich.
Interesting. I thought than when you had a vacuum leak the sytem thought there was too much air so threw in more fuel than was needed. So I am sure someone will put us straight on that one.
I can get hold of an AFR when we do the next valve set but I can't see any other reason for the plugs to be black, exactly the same on all four. Unless it was oil coming through but it's not a heavy deposit. Also with the mpg it just seemed there was too much fuel going in.
