Full Version: question about clutch job
rosenfe
i just put in new clutch ,pressure plateand throwout bearing.got trans mated to engine,but i have a question about throwout bearing.should i be able with my hand to push throwout lever?or does it require cable and foot pressure to activate it.could bolts being too tight on pressure plates affect movement of throwout lever.i want it right before putting all back into car.
mrbubblehead
QUOTE(rosenfe @ Jan 25 2014, 01:32 PM) *
very very little if any. the pressure plate is pretty damn strong. you need the pulley and lever to multiply the force.
rosenfe
QUOTE(mrbubblehead @ Jan 25 2014, 01:37 PM) *
will overtight pressure plate bolts cause a problem in throwout lever action
SLITS
QUOTE(rosenfe @ Jan 25 2014, 01:52 PM) *
Nope, you'll just strip the threads of the fastener or in the flywheel maybe even shear the fastener.
You can push the lever towards the front of the car, but once the TB contacts the pressure plate fingers you'll have to overcome 900 -1100 lbs/in to push the fingers in.
rosenfe
QUOTE(SLITS @ Jan 25 2014, 02:26 PM) *
shear the fastener.
ok ,thanks
