Full Version: momo wheel
topdog
po installed momo, how to remove? thanks
edrotol
QUOTE(topdog @ Jan 27 2014, 01:20 PM) *
pry open horn button.
note the one large nut holding momo wheel to column.
remove nut - forgot how big it is - 19mmm???
done.
CptTripps
After you take the 6 alen head screws off, the center cap should pop off. There's a 19MM socket inside, and it's best if you have the steering wheel locked first.
There's also an adapter that is needed for the Momo wheels. That can come off too. (That's the part the nut is keeping in place.)
dlkawashima
Depending on your point of view the nut that holds the wheel is either 27mm or 6' tall and 180 lbs.
