Mark, I see that you finished making the timing device that you were talking about - well done! Can you make one with accelerometers now so that you can calculate hp and braking distances as well?
mskala
May 27 2003, 05:42 PM
Yeah, this is the same box that I made more than 2 years ago. Never got around to making one with the accelerometers ala g-tech pro, but by the time I get to it they'll probably be in everybody's watches. So I'll never get to use your code. Mark S. '70 914-6
Jeff Krieger
May 28 2003, 12:47 AM
Just as well ... I'm sure a professional programmer would have a good laugh at my code but at least it produces very accurate results.
Chris914n6
Jun 3 2003, 04:47 PM
what's this about a timing device??? is it a cheap DIY gadget after shopping at Radio Shack?
curious conversion driver...
Chris 914n6
need4speed
Jun 3 2003, 05:53 PM
QUOTE(Jeff Krieger @ May 27 2003, 10:47 PM)
Having worked in the software biz for 11+ years, I think a LOT of people would be VERY suprised at what passes for "professional" code.
I think there's a reason Microsoft is opposed to opening their source. . .
mskala
Jun 3 2003, 06:28 PM
The box is a microcontroller and RAM chip, some buttons and an LCD display. It takes the pulses from the points (I have a little cable coming off my optical points-replacement module). Takes 20 samples per second for 10 seconds (stupid me I could have put in enough memory for an hour).
It's kinda expensive to just make one. About $150 in parts. But then I made the software so you could view a bunch of different things right there in the car without having to download first. It will store 3 different runs before you have to offload the data.
