QUOTE(chads74 @ Jan 29 2014, 07:59 PM)
QUOTE(Philip W. @ Jan 28 2014, 03:13 PM)
Here are pictures of mine, PMB installed
You have to be careful with that inside fitting, if the arm goes too low (eg remove bottom shock bolt) it will snap off. Don't ask how I know this.
Could you expand on this please? Perhaps a picture?
In looking at the thread that Bullit so kindly posted and Eric's advice within it (ie-zerk placement correction) I want to make sure I'm understanding the position placement correctly. I'm assuming within that thread where Eric has advised the correct placement is in fact what your talking about.
D
Addedum-I think I see what your talking about and what your meaning was. So your saying, if and when you remove the lower shock bolt, the action of the trailing arm then dropping down can rotate the arm enough to snap the inside zerk fitting. Correct?
Is there another placement point that could avoid this potential problem?
