OK, So several people have followed and suggested things to help in my frustration with the D-Jet on my 2056 Raby 9590 cammed car. while the ECU harness was in fact completely rebuilt. Today I pulled the ECU to check the wiring harness out using the Bosch Factory test procedure. All of the indications for resistance and voltage were well within the specs.
HOWEVER, While checking the harness I noticed that the connector was spread a little wide inside the 25 pin ECU connector. I now believe that was causing an intermittent fault with the ECU grounding. since that is the main ground circuit for the ECU.
Anyway the after re-installing everything and making multiple test drives the car it is running significantly better and I now found a smoking gun to believe was causing the issue. There was no bucking or hesitation at all and the car pulled hard to 5500 RPM. Thanks again evryone
John
