I'm wondering if something is out of whack on my car.
While fitting my inner long, inner suspension console, carrier mount and engine shelf, I came upon a problem. I have the car level side to side (used a level), and when I bolt the carrier to the driver side mount and level it , the passenger side mount seems like it is almost half an inch from where the bottom of the long wants to be.
there was this that happened, of course....
I got a bunch of of aluminum leveling jack stands and distributed them underneath and took out my passenger side door brace to check the door and it seems good, lining up at the bottom along the kick panel.
At one point prior, after I got the inner wheel well welded back in, there was this
which I fixed with plug welds like this
And then the outer suspension console welded on
Even with the inner part of the long taken out entirely, it seems there is something going on. The flange where the mount welds to the bottom of the long is only coming up to the bottom of the lower flange on the long - it should be a half inch up?
so I'm just having a really hard time figuring out where it is off, unless the passenger side of the engine carrier bar is supposed to be either .400" higher than the driver's side? At one point was wondering if it's supposed to not be parallel with the firewall as putting it forward more, the long comes down enough. It's hard to believe the long shrunk that much, almost half an inch? It seems if the doors fit that I got the inner wheel well in right? - i can't put any more metal in there to bring the long down or the door wouldn't fit then, the gap would get too big. A half inch seems gone somewhere ?
