QUOTE(pcar916 @ Jan 31 2014, 09:56 AM)
I think its a little more than just adding PMO's. The 3.6 is rated by Porsche at 270hp, although it's almost always conservative, I'd like to see those dyno results.
I'd never go back to carburetors on a street car... and probably not on a track car either. There is just too much horsepower lost with them over the entire RPM range, your fuel economy sucks, and you'll likely have to change your rocker-arm/ connecting-rod/cam setups as well if you want to access the horsepower gains in the extended RPM range (raising your red-line)... big money. But this thread isn't about that. Oh yeah, carbs don't have a return line anyway.
To your original question, duplicate the 993 fuel line ID's and if you're serious about making a really big engine you're covered without spending any more money on that. There will be enough cash that goes into converting the engine anyway!
yes your right, i over simplified it.....
i am just trying to cover my bases. i hate doing things twice. it always cost money that can be used elsewhere.
do you happen to know the stock fuel line sizes used on the 993/963 cars?
