Mikey914
Feb 1 2014, 08:29 AM
Here's the deal-
I had been buying these from a member in Germany. He has decided to stop making them. I've decided to tool up to make these as he has opted to discontinue.
I have a carbed car and these are basically a choke / and way of setting your throttle to a base RPM as desired on the fly.
Since these have a value I've decided to pick them up. It's a pretty simple set up, the only real cost is the stamping for the lever section. I have a few ideas that may reduce the cost to the $99 area, but I have to see how they work.
I will have these in about 6 weeks, so who's interested? Cost is also a function of how many people want them. If I can do 30 units I will guarantee $99 price point.
So who's in?
somd914
Feb 1 2014, 08:32 AM
I'm interested. Let's see where the price falls.
eyesright
Feb 1 2014, 09:28 AM
I want one, maybe two, possible three.
Would heater cable levers work? I bet you could scrounge for many of these. Would the labor of clean-up/refurbish be cheaper than new manufacture...?
Eric_Shea
Feb 1 2014, 09:39 AM
One complete and one extra front mount if possible.
barefoot
Feb 1 2014, 01:36 PM
QUOTE(Mikey914 @ Feb 1 2014, 09:29 AM)
Here's the deal-
So who's in?
Aren't there lots of similar lever assemblies already around used for throttle or choke control on garden tractors & mowers and such ??
Mikey914
Feb 1 2014, 02:09 PM
The lever is the most expensive part. The rest I can make for about $40, I do make the correct black knobs, so the arm assembly is the biggest cost. If anyone can source them for me I could make these for even less. I had thought about looking at other levers, but had to get a better look at what's out there.
But yes, it would save some cash.
euro911
Feb 1 2014, 02:28 PM
I went ghetto ...
Click to view attachmentActually, this is similar to what I installed in my '67 bus to adjust the dizzy while driving
anderssj
Feb 1 2014, 02:55 PM
I'm interested . . . may help for the 48-state tour
JmuRiz
Feb 1 2014, 04:33 PM
Question, can they be used with a rennshift?
If so, I'm interested, as I know it'd be awesome to have on my other carb'd car.
Harpo
Feb 1 2014, 05:55 PM
I also have a aftermarket shifter so I'm interested but concerned about compatibility
Thanks
David
jcambo7
Feb 1 2014, 06:04 PM
What would having an aftermarket shifter do with it?
ConeDodger
Feb 1 2014, 06:30 PM
QUOTE(jcambo7 @ Feb 1 2014, 04:04 PM)
Not a thing, but let's string them along for a while...
jcambo7
Feb 1 2014, 06:33 PM
QUOTE(ConeDodger @ Feb 1 2014, 07:30 PM)
Oh ok...so I have rennshifter too. Do I have to return to stock to use this?
ConeDodger
Feb 1 2014, 06:56 PM
QUOTE(jcambo7 @ Feb 1 2014, 04:33 PM)
Yes. And send that useless Rennshifter to Original Customs to be used on the DE/TT car.
Elliot Cannon
Feb 1 2014, 07:09 PM
Are we talkin' a poor mans cruise control?
jcambo7
Feb 1 2014, 07:12 PM
QUOTE(Elliot Cannon @ Feb 1 2014, 08:09 PM)
Pretty much.
jcambo7
Stupid iPhone double posted
Socalandy
Feb 1 2014, 07:17 PM
I'd buy one set
sixnotfour
Feb 1 2014, 08:23 PM
QUOTE(Socalandy @ Feb 1 2014, 05:17 PM)
I'd buy one set
Andy do you not have an OG piece for your 914-6 ??? LMK t will be a bit more but OG
KaptKaos
Feb 1 2014, 09:35 PM
Let me know the costs, please.
Mikey914
Feb 1 2014, 11:52 PM
http://www.914world.com/bbs2/index.php?sho...660&hl=handThese work with aftermarket shifters with modification, DEC has a picture.
I have already machined the rod and the the plates. The lever is the last piece. This is one of the projects I just needed to wrap up.
ChrisFoley
Feb 2 2014, 08:29 AM
Mark,
We need to talk.
I've been working since the middle of last year to produce an inexpensive hand throttle kit.
Planned release is this spring.
brant
Feb 2 2014, 08:34 AM
I need one
Kansas 914
Feb 2 2014, 11:54 AM
I need one - if for no other reason too warm the beast up so it will idle - stupid carbs..
So - YES - I am in for one.
Mikey914
Feb 3 2014, 01:02 AM
Kind of nice to be able to set it up enough to warm up. I haven't done much AX but I bet it's nice to not have to have the motor spool all the way up from idle.
Hi Mark,
Nice to see that you make further with these parts
GeorgeRud
Feb 3 2014, 12:48 PM
I'd be interested in one for my conversion car.
Jonathan Livesay
Feb 3 2014, 01:07 PM
One for a 914 and one for a 912.
hcdmueller
Feb 3 2014, 01:42 PM
I need one.
euro911
Feb 3 2014, 01:45 PM
QUOTE(Jonathan Livesay @ Feb 3 2014, 12:07 PM)
There you go ... and advertize on the Bird Board
ConeDodger
Feb 3 2014, 01:52 PM
Love that these are true to the original design. I wouldn't have it any other way on my car.
But now that I am going to a Motronic controlled six, I don't need one. Good luck Mark...
FlatIV
Feb 3 2014, 02:00 PM
I would like one, please.
Mikey914
Feb 3 2014, 02:14 PM
Looks pretty good so far18 units if I count correct looks like $99 is obtainable.
-Mark
Kansas 914
Feb 4 2014, 06:12 PM
I wonder how this will install with a center console...
bdstone914
Feb 4 2014, 06:44 PM
QUOTE(Kansas 914 @ Feb 4 2014, 06:12 PM)
The lever fits in the slot in the front part of the shifter housing. Should not be a problem with a center console.
Bruce
PotterPorsche
Anyone have a picture of what it looks like installed. i'm on the fence
Jonathan Livesay
Feb 4 2014, 06:56 PM
QUOTE(bdstone914 @ Feb 4 2014, 04:44 PM)
Bruce
Well that's a problem for the 912, I didn't think that out. That is where the heater control lever goes. Maybe an extension piece to mount it on the tunnel just behind the shifter? Kind of like where the heater control is on a 914?
Kansas 914
Feb 4 2014, 07:36 PM
QUOTE(Jonathan Livesay @ Feb 4 2014, 05:56 PM)
Bruce
Since I am running headers and have no heat that would be perfect.
Brian_Boss
Feb 6 2014, 03:49 PM
If the final product is as accurate a reproduction as the one from your German guy, I would definitely take at least one.
FWIW, I wouldn't mind a higher price if that's what it took to make it original looking.
Brian
Mikey914
Feb 7 2014, 12:17 AM
QUOTE(Brian_Boss @ Feb 6 2014, 01:49 PM)
Brian
understood,
This should look and function like factory, and as you can see other members have made adaptations for their applications.
morgan_harwell
Feb 10 2014, 07:42 PM
I will buy one set.
Mikey914
Mar 5 2014, 01:14 AM
Progress on the 1st batch, just need to finish the rods.
Mikey914
Mar 6 2014, 01:35 AM
Rods should be done the 24th
Qarl
Mar 6 2014, 07:36 AM
QUOTE(KaptKaos @ Feb 1 2014, 10:35 PM)
If you're still talking orders, I'm in.
Qarl
maf914
Mar 6 2014, 10:51 AM
Mark, I am in for one kit. As usual, thanks for offering this group buy.
duktail
Mar 9 2014, 10:57 PM
Mark, Please count me in for one assembly. Thanks
colingreene
Mar 9 2014, 11:12 PM
id like one.
Mikey914
Mar 9 2014, 11:47 PM
Looks like the rods will be ready a little earlier. I'll keep everyone posted.
-Mark
patrick3000
Mar 11 2014, 01:05 AM
Another order, I'll take one and thanks!
Qarl
Mar 29 2014, 08:31 AM
QUOTE(patrick3000 @ Mar 11 2014, 03:05 AM)
Bump for 914rubber!
