QUOTE(worn @ Feb 3 2014, 04:55 PM)
QUOTE(r_towle @ Feb 3 2014, 11:18 AM)
stock is something like 75 lbs.
aftermarket "stock" is something like 100 lbs.
From there, as far as I know, you jump to 140 progressive springs, or 180 lbs non progressive springs.
Rich
Hey Rich,
While we are talking about springs, can you or anyone else give any suggestions on what spring rate to use for a six conversion? 3.2. I am guessing the originals are too soft.
Thanks
Warren
What will be the purpose of the car?
I would suggest you get bilsteins or koni rear shocks, add the adjustable perches for the nascar style 2.5 inch diameter springs.
They are much lower cost than stock diameter, and you can step up at 5 lb increments....
Front, stock torsion bars, big sway bar with adjustable features to allow you to tune the front end.
Suspension is very application specific.
If you build the front as I suggested, you can do anything with the front....get good strut, koni or bilsteins.
For the rear, get two sets of shocks and springs....it's two bolts to swap them for the weekend....btdt.
Rich
