When I was stripping the tub I wasn't as respectful to the vapor lines running under the rockers from engine to tank as I might have been. Also I am not sure where they all are (no smiley for what an idiot).
At any rate they seem to be a PVC material that is either supposed to be kind of stiff or has hardened with the age. They look black, and I suppose they may have started that way. Other than that they look like tygon tubing.
I can find no replacement source. I probably won't have space for the catalytic converter in the 3.2, but I see no reason not to use this device for reducing emissions. But what should I use?
Great thing is that this group will find me an answer (of some sort). Thanks so much!
