I had the ingenious idea or rebuilding my 1.7 distributor but got stuck when I was trying to pull the trigger plates out. Whats the trick ? Do you have to remove the shaft to get to the trigger plate ?
It looks like the shaft is supposed to be removed from the bottom guarded by a circlip (easy to remove)and a pin thru the drive dog (not easy at all to remove) . How do you get the pin out without destroying the drive dog ?
Also question #2. Are the two counter spings supposed to be different ? Mine are not identical.
And question #3. My breaker plate has some messy broken solder job connecting the upper/lower plate. What was the purpose of that? Click to view attachment Click to view attachmentClick to view attachment
