QUOTE(pete000 @ Feb 19 2014, 01:32 PM)
I agree in CA a 76 914 would be quite the challenge to pass the smog man's evil wand!
The issue with a 76 914 is not whether it can pass the CA smog, since they pass easily when in proper factory spec tune & smog equipment is present & operating properly, as was the case for several other 75-76 owners I know/knew did with theirs.
The REAL problem[b] is/will be when & if you ever need to replace the smog control parts, since they're mostly NLA.
75 & 76 2.0s both have the same CA smog equipment & tune, it's just that the 75 slipped under the wire before the "rolling 30 year old smog exemption" got cancelled by Sierra Club & others' lobbying the legislature, and frozen at the 75 MY then in effect.
So wrecked 75-76 2Ls could be a parts bin, as well as running 75 2Ls willing to risk if CA ever decides to inspect older cars - cuz technically you're still supposed to have
all CA smog equipt. required for that particular MY (or a newer MY for engine swaps - even on later MYs than 75) on or installed & connected, working & operable on all cars/trucks back to 68 MY. Also any outside CA 76 2Ls not worried about CA.
My advice to any CA buyer of a 76 914 is to have a local mechanic knowledgeable in 914s to get them tuned right & smogged to pass the test (preferably one at a "STAR station" smog test who can both test & tune/repair).
Also, since it looks like this 76 914 was never registered outside of CA, IIRC the seller is still responsible to get it CA smog certified within 90 days of a sale at their cost under state law (look at the CA DMV & CARB websites for sale of vehicles & required smog at sale/re-registration events).
So my advice to the seller once you have a buyer, is to make a trip to the nearest AZ 914 mechanic to set the tune to CA specs then go to a Barstow, Yuma or Needles STAR station for the smog - or go back to your former hometown & mechanic/smog station to resmog it, since you cannot get out of the requirement of seller re-smog for the sale even when living out of state AFAIK (unless you register it in AZ or out-of-state at a cost there). Again, check that at the Ca DMV & CARB websites, &/or make some calls to those agencies.
Also FYI in general on 76 914s - there is a different rule for out of state (49 state) 914s, in that they only needed to have their "first sold new state's" smog equipment on, working & pass that state's smog level - IIRC from another really nice lo-mile yellow 76 listed on here in `12-13, which had the 49 state equipment (which was when I learned of that specific "exemption" after raising a similar alarm.
PS - back in the day all MY 70-76 914s had to pass CA smog, most all did regularly with a little fresh tune-up 7/or tweaking by a good mechanic, & my 73 2L always did up thru 86, when I just stored it in my garage pending repairs/resto. Porsche/VW actually did a pretty good job of making these T-IV & 2L -6's pretty durable, easy to meet CA smog limits per MY, & powerful within the smog restraints & technology of the day - the EFI playing a big part in that ability!
Looks like a nice one - Good Luck!
Tom
