Selling my 2.4 liter type 4 engine.
Engine: Type 4, 2414 cc’s, (98x80) Fuel Injected / 175RWHP / 170FTLBS torque
Less than 5 hours on the engine
In action: http://www.youtube.com/watch?v=DRo-C0JpVOs...eature=youtu.be
This engine was purpose built for autoxing and has substantial torque
Many TTOD’s, Class wins in Autox and Hill Climb Records
The engine was professionally built by Mirage Performance in Redwood City, CA
All moving components balanced and blueprinted
Handpicked 1.7 case that was blueprinted
Scat billet crank
Scat rods
J & E pistons (customized for flame propagation)
LN Cylinders “Nickies”
Ceramic lifters
Len Hoffman heads, flow over 240CFM
Raby specified Cam
Pauter roller rockers and custom oiling system
Link ECU – Custom map developed by Neal Havey, Performance Development (Costa Mesa)
Dyno work at Roger Crawford – Heads Up Performance
Additional tuning by Vic Sias
Wire harness custom built by Neal Harvey
Engine control box (Mirage Performance)
Mallory promaster coil
Mallory HiFire cd ignition
Crank timed ignition
Back up Mallory Ignition
High pressure fuel regulator
TWM 45mm throttle bodies
Custom made external oiling system
All fuel and oil lines SS wrapped with AN fittings
Twin oil filters
Kennedy pressure plate and clutch (puck) (spare puck clutch available)
Foley headers
High pressure fuel pump (Marren) and Aeromotive billet in line fuel filter (fuel pressure is 70psi)
(Just rebuilt) Tilton high torque starter
Aluminum Oil over flow Tank
I should have mentioned, everything is Fob Los Altos, Ca.
If you have any question please call me at 650 823-1168 / randalbarrick@msn.com
