jim_hoyland
Feb 10 2014, 08:46 AM
What is the size, length, hardness of the rear caliper bolts ? Do VW shops carry them ?
0396
Feb 10 2014, 09:16 AM
QUOTE(jim_hoyland @ Feb 10 2014, 06:46 AM)
Why guess? I'm sure Bruce Stone will have some plated and looking pretty. Give him a call...just a suggestion as he's local and good to deal with.
jim_hoyland
Feb 10 2014, 09:20 AM
QUOTE(396 @ Feb 10 2014, 07:16 AM)
Good idea, thanks for the tip
For some reason, I thought caliper bolts were not reusable ??
Cap'n Krusty
Feb 10 2014, 10:10 AM
Why? They're not torque to yield bolts, which were probably not even commonly available when these cars were built. If the manual doesn't say "REPLACE", don't.
The Cap'n
bulitt
Feb 10 2014, 02:30 PM
I just happened to measure mine last week for replacement.
12mm x 1.5, 30mm long.
jim_hoyland
Feb 10 2014, 03:40 PM
QUOTE(bulitt @ Feb 10 2014, 12:30 PM)
Thanks
Ho about hardness ?
Harpo
Feb 10 2014, 04:10 PM
They are grade 10.9. Do you need 4 or 8?
Also please don't electroplate 10.9 bolts due to the risk of hydrogen embrittlement.
DAve
barefoot
Feb 10 2014, 05:02 PM
For some reason the Bird includes new bolts in front caliper rebuild kits.
My old ones were perfectly good yet, so have some more stuff in my metric bolt junk jar
Eric_Shea
Feb 11 2014, 04:34 PM
He needs longer ones. Jim, we have them. I'll send you 4.
E.
Eric_Shea
Feb 11 2014, 04:41 PM
Originals (Kamax) are 8.8 BTW. Aftermarket replacements are 10.9
Here's an original next to the ones we're sending Jim.
bulitt
Feb 11 2014, 05:20 PM
QUOTE(Eric_Shea @ Feb 11 2014, 05:41 PM)
Wow! You stamped his initials (JH) on the bolt! You are so awesome!
914_teener
Feb 11 2014, 05:47 PM
QUOTE(bulitt @ Feb 11 2014, 03:20 PM)
Mark Henry
Feb 11 2014, 06:12 PM
Says 8.8 and made in Taiwan.....
Eric_Shea
Feb 11 2014, 06:22 PM
We had them custom cast just for Jim. He's yet to see the bill but, we have all his card info.
Harpo
Feb 12 2014, 06:04 AM
Eric, what is the correct length. Instead of that crap from Taiwan would you be interested in a Kamax bolt grade 10.9 and a better finish?
David
Harpo
Feb 12 2014, 06:17 AM
JH =Jinn Her Enterprise located in Taiwan ROC
bulitt
Feb 12 2014, 07:44 AM
7 N0101274 hexagon-head bolt m 12 x 1,5 x 30
Assuming JH has stock rear calipers?
CptTripps
Feb 12 2014, 08:24 AM
I've never even THOUGHT about replacing caliper bolts. I wonder if I should have. Hmmm....
Great info though. Thanks!
jim_hoyland
Clarification: The rear calipers had spacers added to accomodate vented rotors
Eric_Shea
Feb 12 2014, 12:11 PM
Those are McMaster replacements in the 35mm size. He has to space his calipers 4.5-5mm off the mounting ears.
