QUOTE(mepstein @ Feb 16 2014, 03:24 PM)
QUOTE(Cap'n Krusty @ Feb 16 2014, 04:15 PM)
The FIRST thing to check is the ball cup under the shift lever. Most common failure, and the easiest to fix.
The Cap'n
Mine was broken and it's a super quick repair.
And when you pull the shifter check the plate in the shifter for wear. I checked three of them when I went to sell one and found two of them had excess wear if the plate. I might be able to get you a picture of a bad one.
Bruce
