QUOTE(nathansnathan @ Feb 18 2014, 06:04 AM)
The pressurized washer system doesn't work much better on a bus. I tried to get mine working once and ended up with blown fuses. The problem is the hose to the switch itself will pop off and douse the electrical. It seems impossible to hold that hose on as hose clamps don't come that small.
It is odd that the 914 involves the spare tire in the system.
"Odd"? Think about it. If the washer bottle is full, or nearly so, how much air can you put in it at 40 PSI? I'm guessing about enough to put a couple of tablespoons of water onto the glass before you lose the pressure to push it out. The spare acts as a reservoir for the air, allowing you to put plenty of water on the windshield, multiple times. Of course, if the valve fails, you get a spare tire full of water ..............
The Cap'n
