QUOTE(Cap'n Krusty @ Feb 19 2014, 10:52 AM)
QUOTE(76-914 @ Feb 17 2014, 07:11 PM)
Good one.
And Cap't, it does appear to have a raised flange for washer contact.
I was speaking of the flange on the plug that could be used there. The fan switches have that sealing area incorporated in the design. To answer the switch availability issue, the VW OE or OES switch would probably be best because it's readily available in a variety of temperature ranges, it's cheap, and it fits without fooling around. The paper gasket works fine, or you can opt for the copper washer. There's no relief for an o-ring, so that would be one of the last things I would look at for sealing the joint.
The Cap'n
All good info though I'll stay away from the crush washer. I'm afraid it wouldn't seal well against the plastic face of the radiator. I'm glad you've retired. It gives you more time to answer questions.
QUOTE(2mAn @ Feb 19 2014, 10:55 AM)
never knew they made Sciroccos in 1990
How does that fit in the frunk? Any pics?
Doug, Look in my build thread
http://www.914world.com/bbs2/index.php?sho...=201776&hl= there are several shots of it installed. And maybe it was a Golf or Jetta. I'll have to look back. And somebody needs to set Wikipedia straight on this.......... Volkswagen Scirocco
From Wikipedia, the free encyclopedia
Volkswagen Scirocco
Overview
Manufacturer Volkswagen
Production 1974–1992
2008–present
Body and chassis
Class Sport compact
Layout Front-engine, front-wheel-drive
Chronology
Predecessor Volkswagen Karmann Ghia
The Volkswagen Scirocco is a sport compact coupe produced by the German manufacturer Volkswagen, undergoing two generations of development between 1974 and 1992 and reintroduced in a third generation in August 2008.
