QUOTE(Mikey914 @ Feb 18 2014, 09:30 AM)
Sorry, I was thinking outer. You are correct.
It probably is a switched screw.
READ THE THREAD! He said the screw isn't in there, which is common when the door panel has been removed, which he also said.
On a couple of occasions in the past, I have had to shorten the length of the rod by introducing a couple of bends near the mid-point. Before doing that, I suggest you carefully inspect the inner handle for cracks, as well as the point to which the rod connects to the latch. I have a couple of good latches, as well as some inner handles. They've been in the classifieds for a while.
The Cap'n
