QUOTE(7TPorsh @ Feb 18 2014, 08:23 AM)
Running a 2.0 with Weber 40 IDFs. I had the valves adjusted and carb tuned (tuned?) about 4 years ago. I have maybe put 1000 miles on and off on the car over that time.
What are the signs when things start going out of whack?
The car seems to be running a little rougher, starting a little harder. I hear inhale/exhale sounds when it's having trouble starting.
Porsche mandated valve adjustments at 3000 miles until the 1974 model year. From that point, 5000 miles was specified. The engines didn't change, the amount of service a manufacturer could require for warranty purposes did. 1000 miles in four years? In your case, it sounds like you simply don't drive the car enough.
The Cap'n
