QUOTE(stimpyvan @ Feb 28 2014, 07:15 AM)
We had to add about 80 Lbs of ballast to our RX7 to get to 25/25/25/25. I wasn't wild about adding the weight, but without it the car felt as though it was trying to kill you in every corner (the transition from understeer to oversteer was very abrupt) and 90 minutes of that was very fatiguing. We had already done everything we could to eliminate/transfer weight.
I haven't driven a 914 in about 25 years and I can't remember what the handling was like. Is the preference for a slightly rear weight bias because of the open diff?
What wheels are on the back of that car?
Thanks!
Just my.02 based on what you've written.
Suspension set up is the place to cure an unwanted transision. Consistent handling be it slight understeer or oversteer with no transitions is ideal.I've not heard of any design flaw in the RX7 that would cause this (such as is the case in the 911).
Class rules may preclude taking the steps necessary,( limits on allowable suspension mods, tires, whatever.) however. I have heard of guys building in a transision using progessive springs tho.
Anything to avoid adding weight.
The only dishonest feature of the 914's handlingis the snap oversteer that comes when messing with the absolute limit.....there is no warning, it just goes and there is no catching it unless one is readyfor it, It takes a lot of butt time in the car to know when you're on that edge.....even then it will "gotcha" occasionally.
The rear wheels were made by Monocoque....now defunct. 10 X 16 and 11 lbs each.
22,5 X 10 Hoosier R35 slicks.
I was fooln' with rear tire pressures & got em' a bit low. They were OK at 20 psi...but not at 18.
Damn near ran the tire off the rim
.....didn't go there no mo.
The rear bias helps with traction. TB diff in place. Helps the car rotate controlably in the tight suff at AX.
I believe you can dial this out with balance and wheel and tire combination.
