QUOTE(AE354803 @ Feb 20 2014, 09:49 PM)
QUOTE(Jake Raby @ Feb 20 2014, 08:50 PM)
The problem is where the rocket scientists located the heat exchanger! Its only this way on the GT3 and not the Turbo, or standard 991. They even mounted the PWM oil pump externally! Its in the sump of the other engines, because the GT3 is the only engine with an oil tank.
Pulse width modulated oil pump..... is that the main oil pump?
Its the ONLY oil pump. It handles all scavenge, primary and secondary functions.
Here's the standard 9a1 pump, its much the same as the GT3 pump, but fits inside the sump. This pic is from one of our 4.2s
Here it is from the GT3 intro book for the 14' car.
