with Chris.
S - Suction/Supply from the tank.
D - Druck(Pressure) goes to the engine.
R - Return: this is a bleed off in case the D port is over pressurized. Connect this with the return line from the engine and the return port in the tank. You need a Tee or 'Y' connection to hook the three lines together.
