914ltd
Feb 23 2014, 07:55 PM
I have several pieces for a /6 conversion. Weber IDA, SOLD no water damage inside. Setting years, need clean and kits. With intakes steel air cleaner, $1500. 1969 911 T 2.0 engine long block. Heads, jugs off, includes fan/alternator, this is the same specs as the 914/6 engine, $1200.. 914/6 headers, SOLD 1 1/2" $300. 65 thru 69 911 and 914/6 flywheel SOLD, fits 2.0, 2.2, 2.4, 2.7 engines, $175. Quick 6 engine mount for 4 cylinder chassis, $80. 914/6 steel oil line. Fittings and threads OK, $225. Four 5 bolt cookie cutters 15X6. straight, $500. 911 "M" front struts for 5 bolt conversion, $300. 5 bolt conversion rear hubs, with studs, $200. 914/6, 911 transmission intermediate plate with 911 throttle bellcrank and shaft, $60. Brad
gms
Feb 24 2014, 10:04 PM
emailed sent on Weber IDA, no water damage inside. Setting years, need clean and kits. With intakes steel air cleaner, $1500
type47
Feb 25 2014, 08:31 AM
could you post a pic of the quick-6 mount or email pic to me? Also, are you attending Hershey this year and maybe could deliver items there?
scraperhand
Feb 25 2014, 03:36 PM
interested in the oil line can i get a photo
koozy
Feb 25 2014, 05:21 PM
Brad,
I'm interested in the headers if they are 1 5/8. What is my total, shipped to 95051?
Mike
914ltd
Feb 25 2014, 08:15 PM
mistake
914ltd
Feb 25 2014, 09:36 PM
QUOTE(type47 @ Feb 25 2014, 06:31 AM)
Jim, The cross bar is 1" solid steel.
Hershey is up in the air because of Easter weekend. Brad
sixaddict
Feb 26 2014, 05:25 AM
Dang they did it again
QUOTE(914ltd @ Feb 25 2014, 07:36 PM)
914itis
Feb 26 2014, 05:30 AM
Pls post pics of the rear convesion hub.
Interested.
Thanks
914ltd
Feb 27 2014, 07:26 PM
QUOTE(scraperhand @ Feb 25 2014, 01:36 PM)
Photo posted
914ltd
Feb 27 2014, 07:44 PM
QUOTE(koozy @ Feb 25 2014, 03:21 PM)
Brad,
Mike
Mike, I assume you are looking for 1 5/8 ID
These measure 1 1/2 ID ,1/5/8 OD, just to clarify. Brad
914ltd
Feb 27 2014, 07:55 PM
QUOTE(914itis @ Feb 26 2014, 03:30 AM)
Interested.
Thanks
The hubs are properly faced off on the back side to use 45mm wheel studs
If the plunge is any deeper, the studs can bottom out in the acorn nuts.
This is a very dangerous condition.
ddstaple10
Apr 26 2014, 03:26 PM
Interested in the M struts, could you post a pic?
Dion
sportlicherFahrer
Apr 28 2014, 04:16 PM
Any pictures of the wheels?
smarens
Apr 28 2014, 07:09 PM
any pictures of engine and components of what state/included?
rgalla9146
Apr 28 2014, 07:29 PM
QUOTE(914ltd @ Feb 27 2014, 09:55 PM)
Interested.
Thanks
Absolutely correct.
You could think your wheels are tight when in fact you've only tightened the nut against the end of the stud.
There are solutions, but beware !
914ltd
Apr 30 2014, 07:07 PM
QUOTE(smarens @ Apr 28 2014, 05:09 PM)
I purchased this disassembled. The jugs are rusty and at least 1 has a broken top fin. I don'd see any immediate problems but I haven't taken the time for a close inspection thus the low price. Brad
eyesright
May 1 2014, 10:41 AM
PM sent re:intermediate plate and bellcrank.
smarens
May 1 2014, 08:55 PM
I'm interested in the motor and the bracket, hard to tell what tinware you have, do you think all of the engine tin is there?
Ghianto66
May 1 2014, 11:59 PM
interested w/ fan assembly if you part ou
ghie
914ltd
May 4 2014, 01:59 PM
QUOTE(smarens @ May 1 2014, 06:55 PM)
Should be pretty complete (911 tin) Brad
smarens
May 4 2014, 06:38 PM
PM sent
